Ignition barrel rotating part replacement help needed
Hey there,
I need some help from someone who replaced only the rotating (middle) part of the ignition barrel.
The usual problem reached me, the end of the rotating part, that goes into the ignition module, broke off.
I bought a complete FEBI ignition barrel, but I wasn't convinced by the quality, so decided to change the rotating part only.
I took it apart carefully to know what goes where... and it doesn't want the truth. :)
I need another half a mm for the clip that holds all in place. I tried all, measured all parts.... everything is the same, but it just doesn't want to go together. Everything is the same size to the hundredth mm.
No vid or detailed instructions for "dummies" for the Mk1 or Golf 4.  The Mk2 is different.
I've already spent at least 5hrs with it.... and no.
Anyone who also replaced the rotating part only?
Cheers!
