Coloumbus settings
Evening all
Does the coloumbus have any settings available that allow you to chose what mode it's in on startup ?
I.E can it be set to Bluetooth as default rather than radio?
TIA
This is not possible.
That's a bit rubbish  🤣 I knew I should have bought an android head unit instead of upgrading the bt module  😞
If I switch mine off in media player mode, it powers back on in the same one. Mind you I don't use BT as a media source, just an SD card.
Mine powers up randomly sometimes radio sometimes bt. Its  almost exclusively used in bt mode. I've switched off aux in and took the cd out to see if there's any difference.
Mine always starts with the input that was live when turned off.
I'm going to see if mine does the same
