B1802F1 & B189CF0
Need help with the above codes if possible,
getting an issue with my 68 plate Octavia estate. When I put it into reverse I get several warnings coming up about park assist and manoeuvre braking fault.
B189CF0 - Crash Shut-off - Active is what the code reads
B1802F1 - Nv- energy management - alarm triggered. Is what the top one says, I’m going to change the 12V batter tomorrow.
anyone any experience on these codes?
many help would be much appreciated. Thank you.
l
Edited by Martin1984
Remove photo.
If you are changing the 12V car battery because you have let it get in a too low state of charge and/or state of health then this can throw up all sorts of codes and warnings.
If changing battery it'll need to be a battery in a good state of charge and health (obvious I know but in my experience I've been told a battery "is good" when it isn't, more than once) or if fitting a brand new battery then be (almost) exactly like for like or it'd be best to 'code' the new battery in.
With a (properly) good battery fitted clear the error codes and see if they return.
Is there a reason you couldn't recharge your existing battery with an appropriate battery charger (following the car's 'Owner's Manual' advice on charging rates).
Let us know how you get on.
