What gearbox oil for a 2012 1.2 TSI fabia engine CBZB
Hi
I was just wondering what gearbox oil should be used and if it is worth changing it. Skoda live chat said change every 60,000 a skoda garage I rang said it was a lifetime fluid.
I was just looking for views on if it is worth changing the gearbox oil and if so what oil to use and how much, i think this is 2.1 litres.
Many thanks
If it's a manual gearbox then it's filled for life but the manufacturers idea of the cars life is ten years or 100k.
At 60k I certainly wouldn't bother.
Many Thanks the car is about 10 years old and has nearly done 100k just wondered what the best oil to use is. I should have mentioned that it was manual.
  • Sponsor
Read your gearbox code off the build sticker on the boot floor. Same line as engine code, often.
I probably still wouldn't bother but I use 75/90 fully synthetic if I'm forced to replace due to leakage etc.
Thanks for your help the gearbox code is LMG.
  • Sponsor
The specified oil for that code is part number G 052 512 A2, superseded by G 055 512 A2,  £14.92 + VAT per litre from dealership.
Fill qty is stated as 2.1L but most people report that they are unable to get the full theoretical amount in when refilling, so I would quite confidently predict that 2 litres will be enough.
Thanks again for all your help and time
