Help Identify corroded pipe
Can anyone identify this pipe and want it carries e.g. oil, coolant  and name of part etc.  It's just behind the radiator fans and I am rather worried about the corrosion.
Thanks,
Alan.
Anyone got any idea?
The relevant diagram is supposedly this one, which should be able to be made bigger by clicking on it.
Struggling to pick which of the vast array of hoses is the one in your photo to be honest. If you can tell me which item number you think it is, I'll gladly supply you with part number.
Sometimes these diagrams are over-generalised and don't correspond 1:1 with the reality seen under the bonnet...
Edited by Breezy_Pete
It could also be one of these, which are described as the 'rear' set of coolant hoses, but I think your photo is the front of the engine; though I guess that may be coming round from the back.
Thanks Pete,
I'll take a closer look at the pipe and compare with the diagrams.
Alan.
