Intermittent 'Media' problem
There's an intermittent problem with the 'Media' when using a memorystick (for music) in the USB slot (in front of the gearstick) sometimes it doesn't resume where it was left off from playing on the previous occasion.
With advice from varooom I was able to check the fault wasn't with the memorystick, it appeared to report everything was fine.
I have done the pressing and holding the 'MENU' button to get the hidden/service/engineer menu(s) and information to display hoping this will help those that may be able to tell me how to resolve the issue.
I'm not bothered about updates unless needed to clear this issue (and wondered if perhaps the previous update might cause the issue?).
I assume (always dangerous) I that need to load or reload a program or update but I don't know what or how it's done (extract, overwrite/update) I assume a program put on to a USB stick and then using the service menu(?) to get it inside the machine.
Help and advice appreciated as resolving this issue would be good but me messing up and loosing the facility of music from a memorystick for my wife to listen to in her car would not be good.
Thanks.
Edited by nta16
Same firmware that was on mine, I updated to 0253 and it made it much better.
I do use SD Card for music, as I use the USB for dashcam.
Seem to remember in my ex car MK3 2016 reg you had to press pause> play>pause then it would remember where it was  on the usb playlist when engine next turned on
