Which ARB kits are people running?
As the title says, which ARB kits are people running?
Was initially thinking White line kit, but read a lot of people they squeak after a while which would annoy me too no end.
H&T kit has the bushings made from a Urethane / Teflon composite that eliminates squeaks which I'm leaving towards, but curious on what others have or would recommend.
I recently fitted the lower super pro front arms and the front and rear H&R roll bars to mine.
Used the H&R for the same reason you mentioned. No noise from the bushes and made a good difference to roll and turn in.
only time will tell if the bushes work long term to remove squeaking issues permanently or not.
