Washer and wiper issues
Well guys I don't think the issues I'm having at present are connected and I'm just having a run off bad luck atm. So I previously mentioned the heater blower not working. But yesterday I topped up the screen wash after driving about for a week or so with none in it. I then proceeded to wash the windscreen. The wipers done there thing at the front but there was no fluid. I can't even hear the pump going and the rear wiper seems to want to work every now and again and again no fluid and no noise from thr pump. So is it just potential the pump that's dead or am I over looking a fuse for it somewhere? Also the rear wiper is it potentially the motor dying ?
Also the washer pump does it just pull out off the reservoir?
Yes, yes and yes.
Yes, and it's the same pump front and rear. Most likely you've blown a fuse or burnt out the motor.
So guys I replaced the washer pump with a new one but still nothing . I'm now thinking due to the fact the rear wiper was intermittently working and it's now completely dead as is the pump is it potentially the wiper stalk that's the problem? If so is there anyway to remove the stalk with out removing the steering wheel?
