DQ200 P2841 fault code - no even or reverse gears
Hi,
I've got a 2013 plate vrs with approx 80k miles.
It now has what appears to be a fairly major gearbox (DQ200 I believe) problem which is preventing selecting/engaging half the gears (reverse, 2, 4, 6).
The error code I'm getting is P2841 - shift fork D position circuit range/performance.
Could anyone provide any more info and point me in the direct of what will need to be replaced/fixed - so I can get an idea of repair costs?
I'm assuming this will be a gearbox specialist repair.
I've had no previous issues with the gearbox until this happened last week.
- the gearbox oil was changed approx 3 years ago at around 70k miles.
Is this likely to be a mechatronics issue or something within the gearbox itself?
thanks,
Michael
It’s swarf on the gear selector magnets , take off the inspection panel and clean off the gear selector folks
That has to be the most brief, concise, helpful and money saving response I have seen on Briskoda.
Chapeau to you sir!
It's info and help like that which makes this such an outstanding forum.
  • 1 year later...
Chapeau to you sir!
Sorry for opening an old thread, but did you solve this issue with cleaning the magnets? I have a similar fault code on my DQ200.
Thanks!
