Mk2 vRS Timing Chain Replacement
@AtleszWhat do you want to see about them that you can not see easily using Youtube.
There are no guidelines really for your 2010 Mk2 vRS from Skoda.   It is a non service item.
Are you wanting to replace the timing chain and tensioner because you have issues and it needs replacing ?
EDIT.
PS
Sorry, i see you are rebuilding your engine so you are just as well fitting new parts.
Edited by toot
@toot Thank you for the help. I thought someone has a saved Youtube video which helps. I have found some but maybe someone has a better one or one with a lot of good infos or explanation.
Yep I`m right in the middle of a rebuild :)
