Skoda RNS510 sw update
I got my disc from eBay but the seller isn’t on there anymore. Earlier this year I bought an Android unit off AliExpress and works really well and does CarPlay to my iPhone and has rear camera.
  • Replies 63
  • Views 11.8k
  • H10 is not the number I am looking for. If you don't know how to check HW version you have then pls post picture of a label from upper casing.   Yes, 6276 is the right SW for your unit
  • The guy who had his Columbus fixed by the Surrey company is away on holiday at the moment. I think he's back at the weekend so I will ask him then. In the meantime I've just noticed an Ad from this c
  • PM sent
https://drive.google.com/file/d/1Gnr75jfpnEC9fyfNLqYGYfYROt20dOXr/view?usp=drivesdk
Hi
Anyone having the firmware for RNS510 sw version 6276 ?
Just to jump on this thread...
My head unit is stuck in German with no sound, I've tried restarting multiple times and updating the firmware with a burned dvd-r but no response from the unit. It takes in the disc for a few minutes with a blank screen then spits it back out. Is there a specific version I need for my unit?
I just need Bluetooth and DAB radio, not fussed about maps.
Having trouble uploading images but the label on my head unit says:
3T0035686C
HW:H10
SW:5238
Thanks in advance 👍
Posting Images of the software on the head unit which is the same as the base hardware so mine has never been updated.
Update This Firmware:
https://mega.nz/#P!AgGXoRLZuppgpEyPjdCH9a8KO5NEkWOrU-ccHXcd_uJqD8KneXtJd1Awh5ZLEk85WsJaqeuwTdX8gN_9LUIPlYCCrly8zf8UxZqaJ8OSpuVKPpdEwygosiRQGeGFHHPiOV8y1peqRw4
Password send PM to me
Edited by Cairus
I cant PM yet as my account is new, can you PM me with password?
Could you please share the link with me, too?
I have a problem with my multimedia.
Part number: 3T0 035 686L
Hw version: H26
Sw version: 6270
Thank you
Part number: 1T0 035 680R
Hw version: H21
Sw version: 6276
Thank you @pab567, @Cairus
Edited by atilla
8 hours ago, atilla said:
Könnten Sie mir bitte auch den Link schicken?
Ich habe ein Problem mit meinem Multimediasystem.
Teilenummer: 1T0 035 680R
Hardwareversion: H21
Softwareversion: 6276
Danke@pab567,@Cairus
https://mega.nz/#P!AgGXoRLZupps8x5GXk93wdIk1nbtKS8zJ5kO6kIKeiKc5TU-bQinX1jt00jgYUCeEGU_dbS8OwffxHzQRSd5Y3L8K4hYX-Mun1LjMcsSKJyw09hh4aeAV13WpR7fY1T93nLznSdpyFM
Edited by Cairus
PM sent
Hello, can you help me with the Skoda RCD510 6276 firmware?
@pab567 thank you! Now I have a new problem. Error hdd 6%
https://mega.nz/file/Mr1DFQrI#Fyn-bEmxKITIcPN-WSNdG_02QbnpPtLvjciRjxPyvgQ
It means your disk drive is faulty and must be replaced
@Cairus My RNS510 boots up as VW, how can I make it boot up as Skoda? Is there a direct Skoda firmware file, or is there a different method to make it work as a Skoda?
19 minutes ago, okga said:
@CairusMein RNS510 startet als VW. Wie kann ich es so konfigurieren, dass es als Skoda startet? Gibt es eine direkte Skoda-Firmware-Datei oder eine andere Methode, um es als Skoda zum Laufen zu bringen?
Sorry, ISO for Skoda Boot Logo New Design
https://mega.nz/file/xjkXGazJ#lvX3Z4DtrdMZFtghiDs2mYK7bGqg0OB_pV5_2ZX_jb4
5 hours ago, Cairus said:
Üzgünüm, Skoda Bagaj Logosu Yeni Tasarım için ISO kodu.
Thank you, I will install the file on the device.
On my 2012 Octavia, the push buttons work, but the rotary dial for volume up/down is not active. Also, the device doesn't turn off when I remove the ignition key. Do you have any suggested solutions?
@CairusThank you, I will install the file on the device. On my 2012 Octavia, the push buttons work, but the rotary dial for volume up/down is not active. Also, the device doesn't turn off when I remove the ignition key. Do you have any suggested solutions?
Which HW you have?
No image preview
453.19 MB file on MEGA
I would reinstall the Josi firmware first.
Hangi ödeviniz var?
For HW 2 I would only use the Josi fw.
can someone please provide me with a working link to RNS 510 sw 6276 for VW?
1 hour ago, MHasanX said:
Kann mir bitte jemand einen funktionierenden Link zu RNS 510 sw 6276 für VW zur Verfügung stellen?
This ist VW
