Darkside tuned BKD 2.0tdi Skoda Octaiva - 2005
Make & Model: Skoda Octavia MK2 pre-face lift 2005
Colour: Island green
Mileage: 160000
Price: Breaking - Price list to follow
Description: Breaking as having replaced car with new Skoda
Still has an MOT until 22 September.
*As of right now the car is still complete and has not been stripped into parts* - 7/8/2023
Due to the number of things on the engine and gearbox, I would rather the engine go as one complete unit rather than stripping it down into parts.
BKD 2.0 16V TDi – 02Q 6 speed gearbox
Dyno proven 290hp/460lbft
Looking for offers round £5000 for the engine alone.
I feel that’s a fair want considering that doesn’t even cover the cost of the parts originally, only most of the labor and other bits which went on during its time at Darkside.
Engine is complete with GTB2260VK turbo at 35psi with tubular manifold and braided oil line. New AMC head to rid the porous head issue BKDs are known for with new head studs to take the upped pressure. Oil cooler installed. 120% race injectors. ECU loaded with custom map (IMMO ON) Hardcut limiter. EGR full delete/valve and cooler. Aircon delete. Huge FMIC. Hard boost pipes. Decat pipe for said GTB turbo. Decat pipe for original turbo units using V band clips. 02Q gearbox has stronger selector forks and a Quaife LSD (QDF16R) installed along with Dark sides billet single mass flywheel and clutch kit which has covered about 30k miles.
At the time of parking up, the car was running perfectly. Mapped to run with as little smoke as possible as rolling coal isn’t my thing (There is still a haze, but it’s not clouds of smoke) If driven carefully and off boost, you can expect to see upwards towards 70+mpg, if driven hard you’ll see about 40mpg.
Being honest, I have beaten on this engine once up to temp and since being at dark side it’s never let me down. Never overheated, always had oil changes early (Because modified, DS recommends earlier services, also always changed the oil after track days) The starting from hot issue was resolved by Dark side (Another common thing with BKD 2.0 engines)
The gearbox had started to leak about five months ago. I’m told this is a seal between the box and the engine block. I’ve kept an eye on the gearbox oil and topped up when needed. But I’ve not investigated this anymore, so might be the seal to the block, or it might be something else.
Sometimes selecting 2nd to 3rd can be hit or miss if you’re really pushing it such as on track. I’ve never got to the bottom of this but considering this is probably the same original gearbox the car came with; it might be overdue a rebuild and some love.
The rest of the car, plenty of parts still on it and interior bits. But due to the age, some of the rubber coating from the door handles/switches are going gummy and sticky.
Body is showing signs of rust. Underside isn’t any better.
Do have an android auto head unit, MOMO steering wheel with boss and quick release.
Parts and price list. Unless you want to buy the whole engine as is has aforementioned above:
Hewitt Industries 0-50psi turbo boost pressure gauge with line and nipple for EGR race pipe - £30
Darkside 2.5" stainless de-cat downpipe for mk5 2.0tdi BKD PD140 (Fits standard turbos with V band) - £100
Darkside hard pipe work kit for 2.0 16v TDI PD140 BKD/BKP (Very well used) - £50
Darkside Race PD140 2.0 16v injectors with Firad +120% nozzles - £500
Darkside GTB2260VK turbo for 2.0 16v (BKD), includes tubular manifold, de-cat pipe for the GTB2260VK unit £1000
Darkside Billet single mass flywheel & clutch kit for 02Q 6 speed (About 20k miles on it) £400
4 Bar MAP manifold Pressure sensor Small probe - 03K 906 051 £10
AMC complete cylinder head for 2.0 16v PD140 BKD / PPD170 BMN £500 (Still with engine)
Darkside universal front mounted oil cooler kit - Thermostatic - £80
Vibra technics engine and gearbox mounts for Mk5/Mk6/Jetta/A3/Leon/Octavia £250
Genuine 02Q 6 speed short shift kit £10
Custom BYC rear wing, One of a kind £300
Freaky Parts big brake kit 4 pot Brembos 345mm vented disks £600
Metal undertray sump protector (Never fitted) £100
Turbo Technics S212 hybrid turbo unit (Less than 10k miles used, unknown state, may need refurb) £100
Original BKD 2.0 Turbo (Unknown milage or state) £50
Collection is preferred, can ship depending on part.
Will update post with more parts as I recall if and when.
I’m open for sensible offers on bits, but please understand the car is still complete currently.
Unless you want to take THE WHOLE THING away and save me some time stripping it. It runs, but is currently SORN.
THE TEAM DYNAMIC WHEELS ARE NOT FOR SALE.
Youtube - 3rd gear pull
YouTube - Skoda at Donington 2022
Edited by Volf
Would you split the android auto head unit, MOMO steering wheel with boss and quick release.
Could you take some pics of the android head unit and how much would the stuff above be?
I can do that yes!
Can you give me till the weekend to get the pics/info? As I work away from home!
Not an issue pal
On 09/08/2023 at 16:54, Cropzy said:
Not an issue pal
You have a DM!
