Rapid 2012 Turn on running lights
Hi there,
Please can someone tell me how to turn my 2012 Rapids running lights. I have located the fuses under the steering wheel and there is no switch.
Apologises if this has been asked before.
thank you.
Welcome.
First someone will be able to say if all Rapids have DRL,s.
They do not have to because Type Approved pre 2011.
If it does someone maybe disabled them permanently.
DRLs are supposed to turn on when the light switch is at 0. If you have a touchscreen radio, there should be a DRL option within the car settings (if I remember it correctly). Non-LED Rapids use the main, "long" beams at a low power level as DRLs, so I don't see why it can't be programmed in into a non-DRL car.
