Restraint airbag light
How to turn off airbag light
1) Fix the actual problem
2) Turn off the latching warning light using VCDS or a dealership computer.
Thanks paws4thot yeah I have vag system I hadn't given enough info I could turn the light but it would come back on I was just wondering if there was anyone with the same problem I ended out taking carpet and found cracked wires when you moved your feet it shorted out the problems sorted now if I could do the same with the fuel ⛽ light I'd be happy 😆
