Solved, thanks. Was brief intermittent squeal on startup, then quiet - BMM 2.0 diesel
OK, mystery solved and the marine ornithological population can breathe easy again.
I did some extended on-site investigation (sat in the car and went through a number of cycles of start, no revs, turn off, wait about 5 minutes, do it again) and noted the squeal was only on 'cold' start and not on a warm start.  Revs made no difference.  Managed to locate the noise to the top area of the nearside dash and a bit more poking around identified a fan in the window side air blower as the culprit.
So, nowt to do with the turbo (thankfully) - although in my defence m'lud the noise was from about the same direction.
So, many thanks for the prompt responses; goes to prove just how darned good this forum is.
Please note no seabirds were harmed in this exercise.
Original post:
Either I have a Skua hiding under my bonnet or there's a bearing-type squeal briefly on start up.  Once the revs come up the squeal stops.  I was wondering if it's a turbo bearing not getting oil on start up but that's a guess.  I've checked the sump oil - OK - and no unexpected leaks around the motor.
Car is a 2007 Octy 2 2.0tdi with a BMM motor.
I've tried forum searches but nothing stands out.
Anyone have any more info in this, please?
Edited by MikeTheThinker
Does it happen consistently?
Auxiliary drive belt slipping?.
  • MikeTheThinker changed the title to Solved, thanks. Was brief intermittent squeal on startup, then quiet - BMM 2.0 diesel
Solved, thanks. I've updated my original post with the details.
Are you a Beatle?
I was going to suggest throwing a cup of water on the auxiliary belt to see if it helped, they can become fouled/hard/glazed/loose causing such noises.
Quite often a good dousing of hot water+detergent followed by a thorough rinse can fix such occurences.
Edited by MicMac
4 minutes ago, J.R. said:
Are you a Beatle?
'Fraid not.  I used to play out with youngsters from the extended McCartney family when they stayed with Paul's dad just down the road from where I grew up.  We'd meet the kids en route to school but at the tender age of about 8 or 9 didn't pay too much attention to their backgrounds.
