Brake discs - front
Need to replace front discs on my 2008 diesel 1.9, but there seems to be two options available: one 22mm thick / 280 mm dia; and the other 25mm thick / 288mm dia
https://www.carparts4less.co.uk/brake-discs
I appreciate  that there's not a lot in it, but wondered if there's a correct on to go for?
Can you find a copy of the options sticker for your car?  It would be in the service book or attached to the shoulder of the spare wheel well behind the carpet.
Thanks, I'll have a look in the morning. What will this tell me - the precise part code?
It will give you a list of the option code (aka PR codes) which will tell you which options went into the vehicle build.  Unfortunately, having checked the options codes for the four Octy 2s we have or have had they don't list the front brakes 😞
Plan B; go to LLL Parts catalogue page 2008 O2 front brakes and use the email there to send your VIN and ask them which disks you need.  That should get you a part number.
Edited by MikeTheThinker
I believe the easiest way is to look at the calipers, the smaller disc setup uses calipers marked FS-III.
The larger setup is marked FN3.
Edited by MicMac
EBC on autodoc thinks you have 280x22mm front brakes, but compare the following photos of the front brake calipers to be sure.
280x22mm front brakes 1ZF (ATE brake system)
thumb?id=955168&m=0&n=0&lng=en&ccf=94077844
288x25mm front brakes 1ZE (ATE brake system)
thumb?id=14761113&m=0&n=3&lng=en&ccf=94077844
Edited by Carlston
Brilliant replies; thank you all
Spoiler
Confirmed that it's the smaller disc, after comparing images and FS III clearly cast into the calipers.
Thanks to Carlston and MicMac.
I'm of an age where I started out on MK2 Cortinas and if you had a question you were limited to who you directly know, now the support network is somewhat wider!
Thanks all
Thanks all.
Picture and FS III cast into caliper confirms smaller disc.
I'm of an age where I started out on MK2 Cortinas, and if you had a question, then you could only call on who you knew. Now the network is a little bigger!
