Auto locking at 15mph
kernowVRs
Recommended Posts
I have just bought a 2021 mk3 Fabia last of the mk3, i have run vcds and don't have controller 46 or  35 to do the adaption for Auto Locking
Here is the controller list, I've looked at all the other controllers and nothing there either. Its not a option in the Radio Just all door locks or single
Chassis Type: NJ-SK26 (2Q0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F
VIN: TMBFP6NJ2LZ086745   Mileage: 34178km-21237miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-DKLD)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 AR    HW: 04C 907 309 BP
   Component: R3 1.0l TFS   H20 7057
   Revision: DGH20000    CVN: C1571349
   Coding: 01110032232415080000
   Shop #: WSC 31000 790 00094
   ASAM Dataset: EV_ECM10TFS01104C906025AR 003001
   ROD: EV_ECM10TFS01104C906025AR_003.rod
   VCID: 70EF65C7ABA31A133B-8024
   VINID: 91D49680679A09CA802061C41486769C42
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 R    HW: 6R0 907 379 BA
   Component: ESP9.0i       H04 0006
   Serial number: 08508177200129
   Coding: 43F5247D492B33C6091B106D0056C22492CC9008000DCAF98F00
   Shop #: WSC 31000 790 00055
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 3E738BFFA177BC63F9-806A
Address 08: Auto HVAC (J301)       Labels:. 6C0-820-045.clb
   Part No SW: 6V0 820 045 D    HW: 6V0 820 045 D
   Component: AC Manuell    H02 0206
   Serial number:  2001201B-0238
   Coding: 100000001100000010
   ASAM Dataset: EV_ACManueKMMValeoPQ26 003001
   ROD: EV_ACManueKMMValeoPQ26_003.rod
   VCID: 3365AACB9A35610B06-8066
No ASAM data for: "EV_ACManueKMMValeoPQ26" (SK26)
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 2Q0 937 089 B    HW: 2Q0 937 089
   Component: BCM A0 Std    H10 0934
   Serial number: 01102003400322 Dataset Number: V03935302NP 0001
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_BCMA0 205001
   ROD: EV_BCMA0_205_VW27.rod
   VCID: 397998E3B8599B5BCC-806C
   Subsystem 1 - Part No SW: 2Q1 959 405     HW: 2Q1 959 163
   Component: FHSG_DRV  002 0005
   Serial number: 00000000000037861972
   Coding: 1D0208
   Subsystem 2 - Part No SW: 2Q1 959 406     HW: 2Q1 959 164
   Component: FHSG_PSG  002 0005
   Serial number: 00000000000037650819
   Coding: 050208
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY200102N7N
   Subsystem 4 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0314
   Serial number: 00000000000031870985
No ASAM data for: "EV_BCMA0" (SK26)
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 G    HW: 5Q0 919 283
   Component: PARKHILFE 3K  H10 0056
   Revision: --------    Serial number: 39232003202791 Dataset Number: V03935272VT 0001
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14AU3700000 002024
   ROD: EV_EPHVA14AU3700000_SK26.rod
   VCID: 3D718CF3AC71A77BE0-8068
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V1.clb
   Part No SW: 5Q0 907 572 K    HW: 5Q0 907 572 K
   Component: ACC Bosch MQB H05 0402
   Serial number: 1901200440A833 Dataset Number: V03935243QN 0001
   Coding: 00000000FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   ROD: EV_ACCMRRBoschVW372_VW26.rod
   VCID: 3F8DF6FBA67DB56BF2-806A
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 K    HW: 6C0 959 655 K
   Component: VW20Airbag74D 002 0380
   Revision: --------    Serial number: 003TJ00Y0CDO Dataset Number: V03935227WN 0001
   Coding: 88CCC000000000005C5400CF008800000000
   ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3B7582EBB265A94BDE-806E
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: -----------    HW: 410 820 312 19
   Component: SideSensor_Df  344 0800
   Serial number: 357D4003062F71F1E39M
   Coding: 2D2D2D
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 2 - Part No SW: -----------    HW: 410 820 312 19
   Component: SideSensor_Pf  344 0800
   Serial number: 358D4003262F71F3B15I
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 3 - Part No SW: -----------    HW: 442 152 112 19
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00C935018D17403
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 4 - Part No SW: -----------    HW: 442 152 012 19
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00BF3011D962248
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 6V0 920 940 D    HW: 6V0 920 940 D
   Component: KOMBI         205 2321
   Coding: 272401002180860001882A011000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009051
   ROD: EV_DashBoardVDDMQBAB_SK26.rod
   VCID: 387F9DE78353825333-806C
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 2Q0 909 901 C    HW: 2Q0 937 089
   Component: GW MQB A0     H10 0934
   Serial number: 01102003400322 Dataset Number: V03935310SB 0001
   Coding: 030100042F0A570000000040000000010001070000000000000000000000
   GVL: 01443C0000000000400080000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0 013026
   ROD: EV_GatewA0_SK26.rod
   VCID: 326BAFCF652F68030D-8066
   Generator:
   Component: 2-01-14-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 3V0 919 719 E    HW: 3V0 919 719 E
   Component: E221__MFL-PR6  H03 0180
   Serial number: 000000000E0470040220
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 6C0 915 181 D    HW: 6C0 915 181 D
   Component: J367-BDMHella  H10 9070
   Serial number: 5574103905
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C2 909 144 AK    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  323 3250
   Serial number: CK2C0170 Dataset Number: V03935251YG 0001
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016134
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 72EB6FCFA5AF2803CD-8026
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-ENT2.clb
   Part No SW: 6V0 035 869 H    HW: 6V0 035 869 H
   Component: MU-E-D-ER     696 8742
   Serial number: 04022000022527 Dataset Number: V03935296MV 0001
   Coding: 03620000BE00000001110204018008002F0000C60000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001041
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 4385FA0BCA95D18B96-8016
End-------------------------(Elapsed Time: 03:17)--------------
Link to comment
Share on other sites
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
