P201400 fault code - Intake Manifold Runner Position Sensor/Switch circuit, Trying to determine sensor required to fix?
Hi all,
Any help at all would be greatly appreciated please?
My 2014 VRS petrol EML came on and local mechanic has sent me the above fault code / description.  I contacted Skoda to see if they could suggest the part I need based on the information he provided and without them connecting their own computer to the car one of the technicians suggested based on the sensors around manifold etc and description of fault it could be the Swing Angle Sensor I need to replace (code 06K907386D).
There is no symptom's at all on the car, she is running completely fine.
Many Thanks.
Car at Skoda today and they've confirmed that I need to replace the following.
N82 coolant shut off valve
G336 Intake manifold flap position sensor
Headlight level sensor (not cheap lol)
Nice bill of around 800 pounds.
Would anyone know if there are any recommended options available to block off / delete manifold issues for 2014 Octavia VRS petrol rather than replacing?
Thanks.
  • 1 year later...
Eyup pal. Got this same code on my beast today. Did you get it sorted?
