2011 fabia 1.6 tdi low rev judder
Hello all,
As per title I'm having am issue with my fabia, the car is starting and idling perfect and has no smoke issues while driving but at lower rpm's in 4th and 5th gear it judders quite badly as if its under load. My brothers fabia is same engine and spec and drives perfect at these rpm's in these gears. Showing no fault codes on the diagnostic apart from a historic throttle position sensor code that I cleared and has stayed cleared.
Any help with this issue would be much appreciated
Anyone?
35 minutes ago, agjb90 said:
Anyone?
I'll have a stab, that throttle pedal position sensor code might be a clue that the output is of variable quality, I suspect it's misleading the ECU. Try swapping with your brother's sensor to test my theory.
I will give that a try thanks for the reply 👍
