my third brake light is broken,..
I'm assuming I need to take the complete inside of the tailgate apart to replace it, and that this would be a prudent time to add the backup camera if that was in the planning. Anything else I should watch for? My belief is that some water from the wash nozzle got inside the plastic and then it froze, cracking it.
thanks!
 . Bret
Is this an estate or hatchback as the replacement process is a bit different.
hatchback is a lot easier as it just unscrews whereas estate has some funny clips and a gasket that needs replacing.
my guess as you mention the washer is that it is an estate.
regerding a reverse camera - accessing the inside of the tailgate is only like 10% of fitting the camera so it’s up to you if you wanted to go ahead with something like that at the same time :)
edit:
part number for the estate centre brake light 5E9945097C
Edited by ApertureS
estate.
wow, €70 for the light alone? oha.
The camera is something i'd like to do. I figure it makes sense to do while the tailgate is apart, especially if it's funny clips. I will have to ask someone about this.
 . Bret
