P1400 Egr vacuum regulator solenoid
Hello,
I have this problem that the glow plug warning light comes on and flashes. I am new to the Obdeleven game but I got this fault code:
- P1400 Egr vacuum regulator solenoid valve - error in circuit.
So I replaced the N75 valve since I had one and it didnt work.
I measured voltage in to it and got 12v and 3v out of the both contacts.
Followed the wires into the ecu and replaced the ecu because I had a spare one. But no luck.
Thats where I am now.
Can anyone point me in some direction? And maybe how to troubleshoot with obdeleven?
The engine runs fine. No limpmode.
Did you solve the problem?
I have had this error come on occasionally but the main error for my Skoda is fuel regulator valve low circuit or short to ground.
I have checked the grounding points I could see and all test fine (12.10v like the battery )
