Skoda octavia 5e FL (switch-on time)
4 hours ago, PetrolDave said:
What happened to make the menu item disappear? Any coding/adaptation changes to 5F, any fault codes showing in 5F when scanned with e.g. VCDS or OBDeeven?
Yes i made this changes
Obd 11
6 minutes ago, PetrolDave said:
Then it's best to carry on this discussion in that original thread, since something you did there has caused the problem so the context is VERY importaant.
I have the problem before I change these things
it doesn't show me any error
the problem is that that topic is closed
Then mentioning those changes was irrelevant and not helpful - you should simply have mentioned that the problem existed beforehand.
17 hours ago, Marcii said:
you said if I changed something and I only said what I changed 😬
... but you knew those changes were irrelevant because the fault existed before them - something you didn't mention until a later post :wall:
I'm out.
  • Love it! 1
I'm out.
I'm sorry if I annoyed you... yes, you're right, what I changed above has no relevance to my problem 🫣🫣
