Air Quality Sensor fault
Hi all, I have found my car is throwing up fault code B10A415 for a signal wire is open or short circuit, would this stop my air conditioning working as well? Thks
It shouldn’t but I’m sure someone last year said there’s did
If the LIN network is dead then there could be a chance the air con doesn’t operate.
As the flap motors operate using the LIN network and so do the air con pressure sensors and compressor.
When you say air con do you actually mean air conditioning or do you mean the climate system entirely?
Edited by ApertureS
