remap on 1.8t rs
Just had the car remaped by chippedire.com . The power has improved greatly and no wiring changes were made. It was done through the OBD11 slot and I cannot believe it ....... the car is better on fuel!!!! Highly Recommended.. :)
Better on fuel? I thought, due to the addictive power. they'd go down?
Glad your happy with it!
The reason it is better is that we adjust the fueling and timing at small throttle settings , it works very well . up to 3 or 4 mpg difference proven .
The map supplied was a custom map altered using the dimsport Race program . it put he car upto 235 bhp from 180 hp
How many times on the rollers was it run? Before and after ?
Not to knock you, but 235bhp on a standard 1.8t running on 95 octane ( 98 octane in the Republic isn't readily available is it?) is not possible without major changes to the rest of the car...
I do agree though on the mpg improving, but unfortunately most of us compensate with a little more lead on the foot which evens it out... :D
Its running shell 98 octane , 220hp would be the max on 95 ron
So 235bhp from a remap alone?
Any mods in place on the car? Turboback exhaust, fmic etc?
non std car .
Figures are a bit far fetched i fear!
Most i think you could expect with a map alone is 215 ish. But some cars are a bit stronger than others.
Without an FMIC you wouldnt see anything like 215 on a hot day anyway.
Mine runs 250 even on a hot day! Mmmmmm might just have decided to get a spray kit now.
235? roughly, 220 max
