What on earth is this thingy (that leaking) screwed onto the inlet manifold?
GregFord
Recommended Posts
A leak started two days ago behind the engine. Couldn't see where it was coming from. Pulled the media player out, put in the engine bay, connected the reversing camera and managed to view the leak realtime. Has to buy a spline set to take the inlet manifold off. With the manifold loosened I could see that there is a chamber that plugs into the inlet manifold an that also has the water passing through it on route to the resevoir. Took the chamber off and tried to seal it. Nearly worked but not quite. So I need to order one. Trouble is I have no idea what it's called (or what it does exactly) and I was unable to find a part number anywhere on the part itself.
This is the part in question, that's leaking, but what is it called so that I can order new one?
Link to comment
Share on other sites
Same thing happened to this guy recently Fabia 1.4 16V BXW Removing intake manifold - Skoda Fabia Mk II (2007-2014) - BRISKODA
Function of these sorts of things is generally warm things up to prevent freezing of water content in gas flows.  Maybe to stop the point where the block breather output enters the manifold from blocking with ice?
I think maybe your airbox has no thermostatic mechanism or source of pre-warmed air to help with this?
Earlier generations of 1.4/16V (and other petrol engines) did have (minimum) air temperature control, which often fails in a way that results in all of the air intake being pre-warmed, which ain't ideal.
Link to comment
Thanks Pete.
So it's an anti-icing function, to stop crankcase fumes freezing and blocking the breather as they drop pressure at the valve. Very interesting. The temperature here in Catalunya very, very, very rarely drops below 8C. But anyway, it is as it is.
I have another question (entirely different problem) but I'll start a new thread.
Thanks again.
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
