Sound System problem
Not sure if there is the right place for this question . I have Superb SEL 2015 MK3 , front passenger speaker seem to blown out , the sound there is very bad , is like trying to find a radio station on very old radio even if there is no bad and just talking via bluetooth. The system i have is normal , is not Canton. After some research i understand that there is no amp for the speakers . On my last car i had front line with Pioneer amp and 12inch Alpine type R sub with Audison amp . After i get my dream skoda i discover that is no good idea to add anything to the el. system so i sold everything. What is my option for replacement the speaker , i found that they are riveted so will drill to remove them and add plastic ring and speaker adapter so i can attach neq speakers , i dont want to cut original adapter as my last car . I try to find original speakers around area where i live but i couldnt find any. If i add amp the sound will be much better but i dont want to mess with the car elect. I just want some speakers to buy and replace and will hope to has same if not better sound the original one , not  sure if there is something as one person mention : "Often a well manufactured, quality, factory automotive audio system will have special audio equalization automatically applied to compensate for vehicle’s acoustics and the characteristics of the factory installed speakers" which can lead to that even if get better speaker they can sound worst than original one . My budget is around 150-200€ , im student first year so i cant afford better fronts ( 165mm).
I would recommend these speakers. They really good build and sound quality. 60 RMS so should be ok with some aftermarket amp if you decide to install something in a future. Maybe not that powerful but to change original speakers which I believe 35 RMS is really worth it.
Focal ACCESS 165AC | 16.5cm 120W 2 Way Access Series Coaxial Car Speaker System | Includes Grilles https://amzn.eu/d/aiLphIH
And I used these adaptors but mine was without connectors so not sure if they fit original connectors.
Sound way 6.5" 165mm Car speakers rings adapters compatible with Volkswagen, Seat, Skoda https://amzn.eu/d/8PtMSqb
Those looking good but they are coaxial as i know the original one is component. Isn't that way can make things to sound worst? Where is the handle to open the car there is tweeter, on the bottom corner the one which is broke is count as midbass?
  • 1 year later...
Hello! Did you changed the speakers? What model/kit you chose as replacement?
