HELP - N80 Purge Valve
Hi
Can anyone help me, my 1.5 TSI Karoq keeps brining faults up and need a new N80 Purge Valve.
I have took the cover up and the part number is 05E906517A -  seems to be a impossible part to find online ( before I ring up Skoda) can anyone confirm the different between the 05E906517A and 06E906517A?
I know the 06 is for 2.0 and is available everywhere but wondering if its the same as the 05E906517A.
  • 7 months later...
Hi!
Spent few months troubleshooting my car with this P0441 error - first I tried replacing the valve assembly (by the way, if someone is looking for 05E906517A - this has a new part number now which is 05E133366AN). Changing valve and sensor assembly did nothing, error kept popping up after one day of error reset. I returned this part back to the shop and installed old assembly.
What fixed my error was replacing charcoal canister (part 5WA201801). It is located in rear-right wheel well. Bottom connector was very hard to disconnect, spent 1-2 hours with my mates and ended up brutforcing the clip out breaking it. Attached back with ziptie :)
Now 4 weeks passed, error not coming back.
My car is: Q2 1.5 R4110 DSG, 2020, GABAZG, DPCA, UAG
Nearly every one I have in has a split hose. If you remove the engine cover then where the hose is in a clip on the timing belt cover gently wiggle the pipe and you might see the corrugated hose split. Other things can be over filling the tank causing the canister to become filled with fuel and also the fuel cap seal not sealing correctly. The hoses are around £137 as they contain sensors etc.
