Gearbox fault, ESC and tyre pressure monitoring system.
Hi,
I have 2014 Skoda octavia diesel 1.6 which has almost 92,000 miles. Recently i started to get the following error messages:
1. Gearbox Fault
2. Error stabilisation control
3. Error tyre pressure monitoring system.
If I leave the car on ignition, all of these errors clear after 5-10 minutes. I’ve noticed that before these errors clear the coil light on the dash board go on for a second or two. Once cleared I can start the car with no issues. Yesterday the engine management light stayed on even when all errors cleared.
I ran a diagnostic using OBD 11 and here is the details:
01 Engine
    System description: R4 1,6L EDC
    Software number: 04L906021N
    Software version: 8138
    Hardware number: 04L907309B
    Hardware version: H22
    ODX name: EV_ECM16TDI01104L906021N
    ODX version: 002013
    Long coding: 01250012032501090000
    Trouble codes:
        U112300 - Databus error value received
            Intermittent
02 Transmission
    System description: GSG DQ200-MQB
    Software number: 0CW300047R
    Software version: 5210
    Hardware number: 0AM927769K
    Hardware version: H44
    Serial number: CU501901096869
    ODX name: EV_TCMDQ200021
    ODX version: 001001
    Long coding: 0014
    Trouble codes:
        U010000 - Lost Communication with ECM/PCM
            Intermittent
            Intermittent
03 Brakes
    System description: ESC
    Software number: 5Q0907379K
    Software version: 0371
    Hardware number: 5Q0907379F
    Hardware version: H31
    Serial number: 62494000000400
    ODX name: EV_Brake1UDSContiMK100ESP
    ODX version: 033001
    Long coding: 1A078A9114290970007A060841C8245851289000608224F000410070C002
    Trouble codes:
        U112100 - Databus missing message
            Intermittent
            Intermittent
            Intermittent
            Intermittent
            Intermittent
            Intermittent
            Intermittent
        U112200 - Databus implausible message
            Intermittent
        C114602 - Tire pressure monitoring display Signal error
            Intermittent
08 Air Conditioning
    System description: Climatronic
    Software number: 5E0907044K
    Software version: 0907
    Hardware number: 5E0907044K
    Hardware version: H03
    ODX name: EV_ACClimaBHBVW37X
    ODX version: 003017
    Long coding: 01110104000100011005000000101000
    Trouble codes:
            Intermittent
            Intermittent
09 Central Electrics
    System description: BCM MQBAB M
    Software number: 5Q0937084AG
    Software version: 0134
    Hardware number: 5Q0937084AG
    Hardware version: H18
    Serial number: 01011425900984
    ODX name: EV_BCMCONTI
    ODX version: 013000
    Long coding: 0F001842424700DB07A04082B10407280000000000000000000000000000
    Subsystems:
        System description: WWS371 140822
        Software version: 0570
        Hardware version: 041
        Serial number:         140827141702
        Long coding: 065DDD
        System description: Sensor, DWA
        Software version: 0315
        Hardware version: 005
        Serial number: 000000000ZY141850TEU
        System description: Sirene, DWA
        Software version: 0311
        Hardware version: 004
        Serial number: 00000000000060479787
        System description: G355_FeuchteS
        Software version: 0002
        Hardware version: H07
        Serial number: 20864582
    Trouble codes:
        B126301 - Tank lid unlock activation Electrical error
            static
            Intermittent
            Intermittent
            Intermittent
            Intermittent
            Intermittent
15 Airbag
    System description: Airbag VW20
    Software number: 3Q0959655AC
    Software version: 0200
    Hardware number: 3Q0959655AC
    Hardware version: 012
    Serial number: 003P4PKK2PA5
    ODX name: EV_AirbaVW20TS6VW48X
    ODX version: 001116
    Long coding: 98CCC000000000005C5400CC008800000065
    Subsystems:
        System description: SideSensor_Df
        Software version: 0887
        Hardware version: 008
        Serial number: 3576U000000CAB402116
        Long coding: 2D2D2D
        System description: SideSensor_Pf
        Serial number: 3586U00000084928E01C
        Long coding: 2D2D2D
        System description: SideSensor_Dr
        Software version: 0148
        Hardware version: 111
        Serial number: 3516RA9ED9E04000000T
        Long coding: 2D2D2D
        System description: SideSensor_Pr
        Serial number: 3526R9FF09E04000000N
        Long coding: 2D2D2D
        System description: FrontSensor_D
        Software version: 0149
        Hardware version: 114
        Serial number: 3556V934299040000004
        Long coding: 2D2D2D
    Trouble codes:
            Intermittent
            Intermittent
            Intermittent
16 Steering Column
    System description: Lenks. Modul
    Software number: 5Q0953507DF
    Software version: 0110
    Hardware number: 5Q0953549C
    Hardware version: 002
    Serial number: 29091404221428
    ODX name: EV_SMLSKLOMQB
    ODX version: 017001
    Long coding: 1410
    Trouble codes:
        B116229 - Selector lever park position lock switch Implausible signal
            Intermittent
17 Dashboard
    System description: KOMBI
    Software number: 5E0920941
    Software version: 4290
    Hardware number: 5E0920941
    Hardware version: 204
    ODX name: EV_DashBoardVDDMQBAB
    ODX version: 009040
    Long coding: 27A402082180A60001086A001000000000000000
    Trouble codes:
            Intermittent
            Intermittent
19 Gateway
    System description: GW MQB Mid
    Software number: 5Q0907530S
    Software version: 1188
    Hardware number: 5Q0907530E
    Hardware version: 127
    Serial number: 0002519532
    ODX name: EV_GatewLear
    ODX version: 011016
    Long coding: 030100040F087300EF0002481C0F00010001050000000000000000000000
    Subsystems:
        System description: J367-BDMHella
        Software version: 8043
        Serial number: 8223044603
        System description: E221__MFL-PR6
        Software version: 0130
        Hardware version: H05
        Serial number: 000000000C1255070814
    Trouble codes:
            Intermittent
42 Driver Door
    System description: TSG FS
    Software number: 5Q4959393B
    Software version: 0014
    Hardware number: 5Q4959393B
    Hardware version: 009
    Serial number: 0000119635811
    ODX name: EV_DCUDriveSideEWMAXCONT
    ODX version: 006001
    Long coding: 001000208001040000001100
    Subsystems:
        System description: FOND_FHSG_DRV
        Software version: 0005
        Serial number: 00000000000003868366
        Long coding: 1D0200
    Trouble codes:
            Intermittent
44 Steering Assistance
    System description: EPS_MQB_ZFLS
    Software number: 5Q0909144P
    Software version: 1043
    Hardware number: 5Q0909144P
    Hardware version: 122
    ODX name: EV_SteerAssisMQB
    ODX version: 010031
    Long coding: 8102
    Trouble codes:
            Intermittent
            Intermittent
            Intermittent
            Intermittent
            Intermittent
            Intermittent
52 Passenger Door
    System description: TSG BFS
    Software number: 5Q4959392B
    Hardware number: 5Q4959392B
    Serial number: 0000118861167
    ODX name: EV_DCUPasseSideEWMAXCONT
    ODX version: 006001
    Subsystems:
        System description: FOND_FHSG_PSG
        Serial number: 00000000000003889510
        Long coding: 050200
    Trouble codes:
            Intermittent
5F Multimedia
    System description: MU-S-ND-ER
    Software number: 5E0035874A
    Software version: 0435
    Hardware number: 5E0035874A
    Serial number: S7F02009142412
    ODX name: EV_MUStd4CPASE
    ODX version: 002039
    Long coding: 03730101FF0000001111120100A800002F0000860100010046
    Subsystems:
        System description: ABT_Std_Nav
        Software version: 0030
        Hardware version: H60
        Serial number: SKZ8Z9PT300H4U
        System description:  ECE 2020/21
        Software version: 0094
        Hardware version: ---
        Serial number: --------------------
    Trouble codes:
            Intermittent
76 Parking Assistance
    System description: PARKHILFE 4K
    Software number: 5Q0919283D
    Software version: 0048
    Hardware number: 5Q0919283
    Hardware version: H10
    Serial number: 39231426503942
    ODX name: EV_EPHVA14AU3700000
    ODX version: 002022
    Long coding: 0001050011
    Trouble codes:
            Intermittent
I took the car to Skoda and they were not able to get anything when they ran diagnostic on the car.
any help on this is much appreciated.
If you have not already done so fully and properly check the state of charge (and if possible state of health) of the battery, I wouldn't assume that the Skoda garage has, unless they proved it.
Have you checked that the battery terminal post clamps are secure (don't twist) and main earth connection is good?
Start with the basics, and in this case easy clean-hands stuff.  Put the battery on an appropriate battery charger maintainer (lower amps for longer is my preference) checking the car's Owner's Manual and consulting the manual for the charger for correct way with both (and slowest charge rate for my preference).
Don't just think your battery is fine without doing proper checks.  The computers run on 5v which gets a bit too thin when the battery is well below snuff (as you see I'm not technical).
As you had all the warnings on the car it's unlikely to be your OBDEleven at error or the car's port socket or wiring.
You may have more than one problem happening at the same time or one issue (like low battery) causing, or a contributing cause, to one/some/all other problems.
Failing that it looks like you might have intermittent connections/wires/computers/programs problem(s) with the electrics/electronics or their parts otherwise the Skoda diagnostics (depending on what it was, or was done) would have picked up on it.
Whenever you having (starting or) electrical problems having a fully charged battery will not hinder things but can help or even cure somethings but having a battery that is too low in charge can hinder or even stop diagnosis and/or repairs.  It's so easy to charge the battery to full and if it doesn't need much it won't take long to find that out and whilst the charger is doing its work you can be doing anything, in warmth and comfort, more rewarding and pleasurable than working on a car.  Leaving a charger maintainer on overnight and it's working while your sleeping, difficult to get easier car work than that.
Good luck let us know how you get on.
  • 1 year later...
Hi, what seemed to be the problem and respectfully the solution to it?
