aircon pump
hi to everyone, hope you all had a good Christmas & new year, i have a 1013 face lift superb and the ac compressor stopped working it first stated rattling/jangling when it wasn't switched on but went quiet when i switched the aircon on so i was thinking pully bearing? didn't bother me that much as weather was getting colder but i hate things not right on my cars so priced a new compressor good job i was sitting down when i made the phone call lol, anyway i have found a second hand one with the same make and the same part number. but this used one is coming off a (2007 vw touran) with this being the same make and part number would it have the same fitting points on it?
cheers kev
Should fit as long as it is same OE partsnumber. I guess it is a Sanden PXE16 compressor. Many VW Golf, passat and skoda uses that one or similar. Same bolt ons.
It might be is that your problem is a partially failed shear plate.
The pulley bearing turns all the time, mine is noisy as I used one from a previous high mileage compressor when my shear plate failed during my learning curve of regassing the system, it makes a bit of a RonRonRon drone and gets quieter when I switch on the AC or maybe its when I switch it off.
Whether it is a shear plate or the pulley I would replace them and not countenance the time and expense of replacing the pump which would also involve a vacuum down and recharge.
Having stripped them down the pumps are pretty bulletproof but will throw small and delicate components all over the garage floor when you try to re-assemble them unless you find an apprentice trained octopus!
Edited by J.R.
so can you get air con compressors repaired? at what sort of cost ? obviously the pump would need sending off to where they repaired them if they can be repaired but would that leave the car unusable until the pump was re fitted  ?
cheers kev
You sure its not this little fella that has met its eol? Ac regulating valve.
i couldn't tell you buddy i just know it made a growly/jangly type nose when the engine was running but couldn't tell where exactly it was coming from, then found if i turned the are con on it stopped making the nose. then after some time the air con stopped working and then i realised that there was no tiny increase in the rpm when sat just ticking over, when it was working there was always i small increase on the rpm counter when you switch the air con on at idle.
cheers kev
hi everyone, with summer on the way i finally decided to get my a/c compressor fixed, is there a repair kit for my compressor (SANDEN 1K0 820 859 F) having trouble finding some sort of refurb kit for it? every time i think i have found something it turns out that its from another make and not a sanden there are plenty of second hand compressors for sale the same as mine but knowing my luck if i get a used one fitted it would pack up within a week lol. so i thought of going down the route of getting the one on my car repaired should work out a bit cheaper for me fingers crossed, i am presuming it will need gas out and gas back in ? i have no idea of the price for that + the compressor removed and re fit  + refurb, has anyone had this done and could give me some idea of cost?
cheers kev!
Look at the shear plate, it sounds like it has let go.
Other than that, a noisy pulley bearing or the modulating valve they are bulletproof, there really are no parts I can think of to make up a repair kit worthy of its name.
thanks for reply, so is my only option to but a new compressor?
cheers kev!
No idea beyond talking to an automotive air con specialist and not a Skoda main stealer!
ok thanks!
