Sticking window
Afternoon we have a 2021 mk3 Skoda Fabia , warranty is up mid March. Today front passenger window went down and at wouldn’t go back after a bit of coaxing eventually went back up . Possibly window regulator gone or about to go , quite noisy when window close to bottom. Noticed driver windows noisy closer it gets to fully down but still working. Just wondering if anyone has had this issue and if it was regulator and also being this close to end of warranty has anyone had success getting them fixed under warranty or I am likely to get told wear and tear?
Ask the Dealership or warranty company if this is covered.
Are you closing the window with the engine running or not, if not perhaps low battery and/or the guides need cleaning and lubricating or it could be the regulator or motor or some alignment or partial blockage issue.
I'd start with at least reporting it and seeing if it's covered or chargeable, then if required cleaning/lubricating (many servicing, maintenance, repairs, computer stuff often boils down to some sort of cleaning and lubricating).
If you have access to a relevant scan tool it could give you further diagnosis and testing.
Last for me personally would be taking the door panel off and messing with parts.
Update car in at garage today regulators replaced in front doors working again , work done under warranty
