Windscreen washer not working // with rear wiper
Recommended Posts
I have a problem with my skoda octavia mk3 2019. The windscreen washer don't work alon with rear wiper.
- I already checked the fuses they are all OK
- the washer pump does not run
- measured the voltage at washer pump, I have 0 V with the stalk commanding the washer pump on
Any other guidance please
Link to comment
Share on other sites
Have you checked the fuse?  I think (please check your manual) that it is Fuse 27 in the glovebox.
It may well be the motor that has failed.
Link to comment
In the manual, I have fuse No 47 for the rear wiper motor.
I replaced all the concerned fuses preventively.
The front wiper motor (fuse 19) run correctly but the washer does not
Link to comment
The system would have thrown a code for a failed washer pump.  Can you get your car code scanned and see if there is an error present please?
Link to comment
I did read the system with an ELM OBD nothing
and then with an AUTEL, I got the error in 'Wiper motor control unit' but the motor work fine when I run it with stalk
Link to comment
The car is not lying. It's saying the wiper motor is exhibiting high electrical resistance and is probably on its way out.
Two areas to look at: grease the cardon shaft from the motor to the blade (because that can sometimes bind) and if that doesn't work, replace the motor (ideally with OEM)
Link to comment
Hi,
I rescanned the vehicle today with another Launcher, I got this code B126101 Windshield washer pump electrical error
I replaced the washer pump with a new aftermarket one and cleared the code
I tried to use the windscreen washer but always the same fault, not working again with the same trouble code (B126101)
Link to comment
On 27/01/2024 at 19:11, Bowmoh said:
Hi,
I would electrically check the old pump if you still have it. Check it electrically and also with a power supply. If it works then the issue is probably not the pump, it will be wiring somewhere (check earth's on the tailgate). BTW.... aftermarket devices are not good. Did you electrically test that one before installing it? Just because it's new it doesn't mean it's any good. BTW...I have found VAG products are usually similar prices and at least you will have a good known product.
Edited by varaderoguy
  • Like 1
Link to comment
Hey Guys, bit confused here OP says the rear washer isnt working and yet they say they are checking fuses for the wiper motor not the washer pump? ....is it a single pump that does both front and rear  because if the pump work ok for the front washers its not that? if your getting 0v at the pump its not the pump it'll be the supply wiring, fuse, rotary coupler, stalk control etc...can you use a power probe to supply power to the pump itself or bench test it and check its working...id start by checking the fuse for the pump then if ok activate the stalk and see where you loose power along the circuit till you find the issue?
Link to comment
yea thats what i figured, if its working ok one way then its ok..its gotta be the power supply as itll be a single earth, start with the fuse then follow the power...electrical faults are never nice on modern beasts
Link to comment
I've read the original post and OP says the windsceen washer isn't working along with the rear wiper
Are you saying the pump doesn't work for either front and rear?
Link to comment
Something I noted from my mk2 estate. If the boot was not fully closed the washer and wiper is inhibited. So it may be something to do with the boot closed microswitch.
  • Like 1
Link to comment
There is only one pump that supply the frond and rear
I tested the pump directly on a 12V source, it worked
but through the stalk it does not work
Link to comment
Does it work in both directions when you reverse the polarity?
Link to comment
  • 4 weeks later...
Yes it does work when I reverse the polarity
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
