Superb 3T Elegence V6 wagon
I've finally joined the Skoda Club.
After months and months of umming and erring I finally did it and got SWMBO to allow me to get rid of my boring 6 and into something interesting again.
Currently unroadworthy and unregistered - parts have already been purchased and I'm waiting for them to enter my hot little hands so I can get to work on her.
No name yet, but thinking Stealth as once finished, all the badges will be blacked out and the alloy's as well.
Parts coming (just to get it roadworthy)
DBA T2 discs front and back
ATE Ceramic pads front and back
Sway bar links (doing all 4 but only 1 required for the roadworthy)
Rocker cover casket.
The pads were hard to find here in Australia so they are coming from Lithuania quicker than the discs are that are here in Australia!
I do have a question about the battery though. Does it really need to be coded? I've got an OBDEleven coming so (as long as I've bought the right one) I can do that.
Welcome to the forum cobber. Battery adaptation (coding) depends on whether or not your new vehicle is fitted with micro-hybrid energy recuperation - does it have automatic idle stop (stop-start)?
Edited by Warrior193
typo
Ok, I'll have to check for that. There was no engine cut out when stopped at lights on the test drive or the drive home so guessing that it doesn't.
Well, there is no start/stop button in the car so guessing I don't have it.
Hello, see the attached image below for the automatic idle stop button - if your new vehicle doesn't have this button somewhere on the instrument panel1979038293_skodaautomaticidlestopbutton.thumb.jpg.964d6ab56ee45bb5b49afce29cb19361.jpg, it's probably not a micro-hybrid - in which case, you don't need to carry out any adaptation when fitting a replacement battery and you don't require an EFB or AGM type.
Yeah, no start-stop button in the car or the manual. No coding for me 🙂
So, here comes more questions that I hope I can get some help with.
Purchased an OBDEleven and got the following errors:
Fault code: 00883
Issue: Ignition/starter switch (terminal S) Implausible signal
Status: Intermittent (feeling it's now static as car won't start but there's also battery issues as well)
Fault code: 01625
Issue: Front Parking aid warning buzzer Open circuit/short circuit to ground
Status: Static
Have worked out I need a new buzzer
Fault code: b105a1b
Issue: Covering for fuel level indicator sensor 2 Resistance too high
Status: Intermittent (explains an issue I had when I picked the car up not showing how much fuel was in the tank. Not had it since though)
Fault code: 02811
Issue: C steering column lock control module No signal/communications
Fault code: 02233 & 02234
Issue: Left & Right headlight power output stage. Lower limit not reached
Status: Static
Fault code: b11df13
Issue: Rear lid warning buzzer. Open circuit
Status: Static
I cleared the faults and only the rear lid one remained. Have tried to do this again but the battery is now dead so not going to bother charging it as I have a new one coming in a few weeks.
My question for this last one is this. Is this the same buzzer that's for the rear parking sensor? I've googled it and found absolutely nothing on it. The fault code gives me no results.
Also, should I be worried about the other codes that have appeared?
I'd suggest waiting until the new, fully-charged battery is fitted, then resetting all fault codes and taking things from there. All sorts of (often spurious) fault codes can be common with a faulty / discharged battery.
So an update - things going super slowly more due to not really having enough spare time and money.
Also, found out really quickly that I didn't have the right tools for a lot of the jobs so have needed to enlist help from friends which has been even harder to tie down when they and myself are free so I've done some things and had a few wins as well.
Front discs and pads done - had a friend do these who used to be a Euro mechanic a few years ago. He took 1 look at the rears and went without a hoist I'm not doing them. so it's now of to a Euro garage for that and the sway bar link's to be done.
Battery replaced and lo and behold it fixed a warm aircon! Didn't think in a million years that would get fixed like that but saying that, the battery was well under-sized for the car so guessing there just wasn't enough juice coming from it for all the electrical stuff.
Only 1 error code remains on the OBD and that's the Rear Deck Lid speaker. Now I know where that is just need to order another speaker (had to do the one behind the dash for the parking sensors which I did today. Boy that was a pain)
Got new alloy's on which need a balance.
Car is booked in for the 29th April to get the work required done (need a rear wiper motor as well, as nothing happens other than the water pump from the reservoir - no water or movement at the rear) - so 3 months from when I got her.
Can't wait to get her registered and on the road.
And that's all done and she's now registered and back on the road.
OH MY GOD what a car it is to drive. So bloody fast to the speed limit.
Now, the next things on the to do list are the suitcase muffler (middle one), upgrade the head unit and get a rear camera installed.
Oh, and a dash cam as the drivers here in Brisbane are bloody ridiculous.
Looks awesome they do drive great dont they. An upgraded headunit and rear camera is on my list to do too :),
Update time - albeit a small update
Finally found the right hub covers for the alloys I purchased.
I knew I needed new alloys from the start as (see pics above) they were totaled and at at least $250 (around 125ukp) a piece to repair and then the near $1000 (500ukp) for the tyres, the budget didn't quite stretch to cover all of that so I went hunting on Facebook and other local selling sites for alloys that would fit.
Found some (the one's on the car atm) for $400 (200ukp) with Bridgestone Potenza RE003's on them that had around 6-7mm of tread on them so enough to pass the roadworthy inspection. I had no hub caps though.
Not thinking it through I just went and ordered some cheap things from Aliexpress thinking they would fit and of course they were too small. Measured the gap and ordered some more - too big this time. So I gave up initially and then realised that these alloy's were never sold on a Skoda so went hunting for the right car and thanks to Google Lens I found it - Audi S3. Once I found the right part number I ordered some BUT they would have either an Audi or VW badge on them. Thought ah well, just get the Audi one's and get some stick on Skoda badges and see if they will cover them. Well, they did once I removed the Audi symbol from the hub cover.
Don't look too bad I reckon
