Roll cover
Don't know if this in correct section so apologies if not. I have a 2018 Karoq Sel 1.5. Bought in Dec and am really happy with the car. I do have one small issue I'm hoping someone can help with? The roll cover parcel shelf. The "anchor points" that are on the boot trim. It looks like previous owner either attached cover incorrectly or there is a manufacturing issue with the trim. The plastic tab that attached to the cover is practically snapped. You can see the plastic has turned white where it looks like it's been forced into a position or direction it wasn't meant to. So as I drive along or close the boot the cover unhooks on the one side and sags. Drivers side is fine. I've tried to search for solutions but not sure on correct terminology for my issue. Can anyone help, even with a work around???
Ian, you might get more, and more specific, replies (or find the subject already covered) in the Karoq forum, you could try a search or a post there. - https://www.briskoda.net/forums/forum/365-škoda-karoq/
HTH.  Good luck.
Thanks mate
