Interior and boot lights stopped working
  • Interior and boot lights stopped working, and the dashboard went to lowest setting dimming lights when ignition is on, I had led lights in boot and when I was trying to turn on the lights and the engine was on, it was showing as I would actually open the boot. i have put the stock lights in boot and now that is not showing anymore, but the lights still don't work and the dashboard does the same, the only error I get is
    OBDeleven vehicle history log
    Date: 2024-02-06 09:58
    VIN: TMBKH7NP3J7502994
    Car: Skoda Superb
    Year: 2018
    Body type: Estate
    Engine: CRLB
    Mileage: 134100 KM
    Fault
    Control unit: 01 Engine
    Active faults: 0
    Inactive faults: 0
    System description: R4 2.0l TDI
    Software number: 04L906026ET
    Software version: 1990
    Hardware number: 04L907309R
    Hardware version: H24
    ODX name: EV_ECM20TDI01104L906026ET
    ODX version: 002002
    Faults:
    No trouble codes found
    Mileage: 134100 km
    Date: 2024-02-06 09:52
    Fault
    Control unit: 02 Transmission
    Active faults: 0
    Inactive faults: 0
    System description: DQ250-6F MQB
    Software number: 0D9300043B
    Software version: 5205
    Hardware number: 02E927770AS
    Hardware version: H54
    Serial number: TFK01705050068
    ODX name: EV_TCMDQ250021
    ODX version: 001001
    Faults:
    Mileage: 134100 km
    Fault
    Control unit: 03 Brakes
    Active faults: 0
    Inactive faults: 0
    System description: ESC
    Software number: 5Q0614517CH
    Software version: 0743
    Hardware number: 5Q0614517AH
    Hardware version: H62
    Serial number: 61407000001031
    ODX name: EV_Brake1UDSContiMK100IPB
    ODX version: 036010
    Faults:
    Mileage: 134100 km
    Fault
    Control unit: 08 Air Conditioning
    Active faults: 0
    Inactive faults: 0
    System description: AC Automat
    Software number: 3V0907044CS
    Software version: 4402
    Hardware number: 3V0907044CS
    Hardware version: H34
    Serial number: 00000B00538397
    ODX name: EV_ACClimaPrehVW37X
    ODX version: 002025
    Faults:
    Mileage: 134100 km
    Fault
    Control unit: 09 Central Electrics
    Active faults: 1
    Inactive faults: 0
    System description: BCM MQBAB M+
    Software number: 5Q0937084CP
    Software version: 0253
    Hardware number: 5Q0937084CF
    Hardware version: H36
    Serial number: 01001713200380
    ODX name: EV_BCMMQB
    ODX version: 018001
    Faults:
    U110100 - Component protection active
    static
    Date: 2024-02-06 09:50:44
    Mileage: 134100 km
    Priority: 4
    Malfunction frequency counter: 1
    Unlearning counter: 205
    Terminal 15 status: On
    Terminal 50 status: Off
    Voltage: 12.1 V
    Outside air temperature: 12.0 °C
    Status Bremslichtschalter (HW): Off
    Status Bremslichtschalter (CAN): Off
    Off: operated
    Parking light: not activated
    Automatic high beam assist: not activated
    Low beam: not activated
    Parking light left: not activated
    Parking light right: not activated
    Letzte Weckursache/ Werte [00;2E]: gültiges Funktelegramm
    CAN-Bus_aktiv: On
    Mileage: 134100 km
    Fault
Edited by ColinD
I had those symptoms in summer. Dealer tried to remove component protection, but did not succeed. Had to replace BCM.
In the component protection mode all the interior lights are out, screens are dimmed, seat heating is also disabled.
Yep 100% the BCM mine went on my previous superb.
about 500 quid replacement then the labour to code
sorry to be the bearer of expensive news
At least i know what to expect. Thank you for the replies
Do you know if i can still use the car before it's fixed?
  • ColinD changed the title to Interior and boot lights stopped working
Yes, car works, but with some limitations described abow. I had to drive for a month when waited new service slot to replace BCM.
