Škoda Favorit 1.9 TDI
I've stumbled on this. Here is something new.
The setup may output 200nm + of torque. It might surpass 1.8T conversions by torque output.
What do you think?
 The weakest stock 1.8T has 210Nm of torque, which is same as stock TDI. I don't see a point of this conversion, heavier, weaker, same effort to get it in.
If they used a more modern PD unit, it'd be a different story
8 minutes ago, R_Blue said:
How about this one?
320Nm @ 1900rpm 😱
110kW ARL - that's one of PD engines I mentioned. Similar engine was used in Fabia RS.
I can't recognize which engine they used but, can Favorit handle that much torque?
The engine is an early TDI with rotary injection pump, used in MK3/MK4 golf. Those had 210-235Nm.
They swapped the gearbox, too, the weakest points are now driveshafts and car's body itself.
Edited by Papez
So if it was a PD engine it could end up like: (Not because of  those crashes but x3.2 of designed torque) 😀
But, it's good to see Favorits are still getting some attention for engine swaps. I hope the author on youtube completes their project and posts more videos about it.
I think a Favorit is better built than a Renault 11! ;)
The overall power is same or lower as 1.8T conversions, so it's not any worse than that 😃
it is!
How they put the 1.9tdi VP gear box? What the mount need to use for the felicia pickup?
I'd like to know that too.
