my new(to me) nearly "poverty spec" Superb
actually there is one observation I meant to make after taking a ferret around in the settings.
I notice that under the ACC options you can configure it for Comfort|Normal|Eco|Sports however the car doesn't have a mode selector to switch between these in "non acc" driving.
Is it possible to add the switch or would it likely also need wiring loom and coding??
Looks like a good one. You want to ask @ApertureS about the switch.
  • Sponsor
This is simply just how aggressive/economically the ACC itself behaves. You only have the option to change it manually because you don't have drive modes, if you had them then the ACC would be adjusted automatically
Drive modes are SWaP so protected features
They can be added but they're not cheap. It's not just a case of adding a button and turning it on
Edited by East_Yorkshire_Retrofits
cheers
so no option to add them as an infotainment option without a button? shame as the settings are obviously there ;o)
  • Sponsor
1 hour ago, Winston_Woof said:
cheers
Drive modes aren't located in the infotainment unit, they're in the diagnostic gateway. They aren't functional without a valid license for each drive mode
We can install them though 🙂
35 minutes ago, Winston_Woof said:
cheers
apologies, that was a tongue in cheek comment. I did understand what you originally wrote.
I was merely pondering outwardly :)
