I need help with bcm unit from a 2011 skoda fabia 2 1.2 tsi
i want to power this up the bcm and connect to it using vcdss and also make it work with an instrument cluster. The only wire i have found is ground wich is a brown wire. The can bus and the k-line diagnostics wire are on the white plug. Does anybody have a pinout for it?
