12v charger for 6v battery
I've got a 6v motorcycle battery that I need to charge, but my current battery charger is only for 12volt car batteries.
Now if my memory serves me right I can adapt this charger by creating a lead between positive and negative with 2 resistors of of the same value, then taking power for charging from between the 2 resistors, which should be 6volts.
Am I correct here? Or have I just made this all up.
Wait a minute, I think I may have slipped up and this is a 12v battery anyhow.
Well charged it today, seems to have survived ok.
Just out of interest, would my originally proposed idea have worked for a 6v battery?
With just the resistors in place you'll measure 6v between the resistors but introduce a  load(battery!)  then it all changes.  Voltage drop more determined mainly by V=IR over the first resistor where the current drawn will be determined by current through the second resistor and drawn by the battery.
Something like this will do the job... https://www.amazon.co.uk/EBILUN-Converter-Voltage-Changer-Regulator/dp/B07HCC8C6Z
Edited by bigjohn
Thought my way seemed way too easy.
