Noisy/tappety sounding 150 TDI
Hi all
Long time no post.
We have a late 2015/65 Mk3 Superb 150 TDI 4x4. Now on circa 50k miles.
Late last year the engine suddenly got noticeably noisier than usual - a very "tappety" / "ticky" sound, very obvious - you can hear it as the car drives down the road.
It varies directly with engine speed; it's there from cold but does seem to get a little louder when the engine is warm.
Car is driving fine - no change in performance or economy.
No oil loss, mayonnaise, coolant loss. Just the noise.
It's in the garage at the moment for some diagnosis, after a listen with a stethoscope they say the noise is roughly from the alternator / fuel pump area.
I wondered if anyone else had this issue, and if so, what was the outcome ?
Many thanks!
Edited by muddyboots
When was the last oil change?
Just following this up, as the cause was discovered yesterday.
The cambelt had jumped - apparently the cam was 1 tooth out from the crank, and the HPFP 3 teeth out (so I'm told).
A quick trial with the cam back in time and it was much quieter.
Garage are now fitting new cambelt/tensioner/water pump etc.
FSH with Skoda from new (but now at an independent specialist). Cambelt was done previously by Skoda, maybe 3-4 years ago now.
@muddybootsLucky save there.
Are you having the independent doing the servicing on your Haldex?
Did a main dealer do that last time?
Main dealer did Haldex previously, good for a while yet.
Further update.
Previously we'd had an issue with a leaking adblue injector, which resulted in a large white buildup of crystallised adblue in the area. The injector was replaced, and all the visible residue removed - but it seems there was quite an unseen buildup inside the adjacent cambelt cover. I'm suspecting a chunk of this fell off at some point and caused the belt to jump.
All cleaned now, new cambelt/water pump, fully serviced - and it's all back to how it should be :)
