Heater Blower Malfunction advice
Hi all,
I drive an Octavia Mk3 2015
Recently my AC/hot air both stopped unexpectedly. No warning signs.
fuse was okay
removed my original blower motor and tested it, the motor worked fine but the resistor seemed damaged.
There was a voltage coming in through dash cable
vents all seem to be working okay
i bought a second hand blower-motor and resistor part to replace mine, now my air is working but it is often remaining on, even if I remove my key from the ignition and turn all power off the air continues to blow and cannot be turned off (with no engine running/key in!)
it continues until I disconnect the blower/motor cable manually
I wondered should I aim to get a second new resistor?
Or could there be a problem further up the electrics in my dashboard or elsewhere?
cheers
JC
Get it checked for codes.
