Cruise control fabia Monte Carlo tech
What's involved in fitting cruise control to Monte Carlo tech with 1.6 tdi 13 plate. I have VCDS and already made some changes.
On my vRS.........a rough guide...
Fitting of new indicator stalk / switch (so steering wheel  / airbag removal etc)
Wiring to indicator stalk plug / connector
Wiring to main fuse box / adding terminals / fuse
Wiring to engine ECU connector / pin  (on petrol, diesel "may" be different) this involves access to scuttle area where wiper motor is, so wipers off etc and drilling through into wiring connector on bulkhead.
Replacing BCM (plug and play but access is fun)
Configuring BCM with VCDS or similar capable tool
If you buy a genuine VAG kit, it comes with destructions and is fairly easy to follow.
Attached is the overview showing which part number kit you would need V spec of your car, do NOT be tempted to buy a cheap one which is not the exact number / kit you need.
I got mine from Skoda dealer online at a good price, around £200, always worth asking for a bit of discount.
Cruise_control_overview_2_2013_pdf.pdf
Thanks just what I wanted.
