ABS sensor wire **** up!
Hi,
Today my son was “helping me” with the front brakes and for some random reason pulled on the ABS sensor wire.
The wire pulled out of the connector so one job leads to another.
My question is, does the polarity of the wires matter when I reconnect everything as I have nothing to tell which wire goes to which terminal in the connector?
So at the moment, the ABS light is showing on the dash as I just insulated the ends of the wires and sealed the ABS sensor terminals from water ingress.
If it does matter what will I see if I get the wires the wrong way round!
All thoughts welcome!!
How many wire cores?
There are two wires
  • Sponsor
One of them is black, yes? That came out of connector pin 1 (will be numbered somewhere, possibly wire entry side).
Yes it is, thank you.
As I’m always keen to learn, what happens if it is connected the wrong way round as I understand an electrical impulse is generated by the interaction between the disc on the hub and magnet in the sensor?
  • Sponsor
Dunno, but some of these sensors are active/polarised,  I seem to remember.
Experiment if you're keen.
:biggrin:
The sensor is like a guitar pickup, a coil of wire surrounding a magnetic pole piece, the sensor generates a very small AC voltage of a frequency depending on rotational velocity, if you connect it up the wrong way round nothing bad will happen.
Thank you for your detailed reply. 👍
