n75-valve-turbo-boost-pressure-converter clicky
Evening,
i've a small noise when blipping the throttle (Only just audible in the car and when right up to the bonnet) whilst stationary and also a clicking odd noise after turning it off. So on the drive i started it up and heard the Turbo boost valve clicking away, im not aware i've ever heard it clicking like that before. Rest of the car is running fine, garage changed a glow plug at xmas. So what is the collectives thoughts it is just a new valve required or is it the start of a bigger issue maybe ??
Car 2014 Rapid Spaceback 1.6 (150,000 Miles)
Thanks in advance
Adam
  • 6 months later...
Hi have you fixed this issue?
not sure if mine does the same ?
I’ve ordered a new oem valve however lots of other people online saying it’s likely the vacuum hoses not the actual valve
Ideally needs a smoke test or use some tie wraps/clips on the hose connections
