VCDS Real Time Advanced Measuring Values from block 36-Seat Mem. Drvr
Hi,
I'm having troubles with my new to me Skoda Superb 2015 TDI 2.0 memory seat and I'm starting to think that problem might actually be the physical memory buttons.
I have a VCDS and I checked that there is no active faults on memory module. Then I checked Real Time inputs from the module and for example when I moved the seat I could see that position values were changing. However when I tried to find correct inputs for the physical memory buttons (SET, 1, 2, 3) and selected those, I could not see any change on status of the input. Those where constantly showing "not active" and I guess that is same as not pressed.
Can someone please confirm that what variables from the variable list are the ones that are indicating status of the physical button (pressed/not pressed (active/not active))?
I will add picture about what variables I tried. It would be nice to know that I'm checking correct variables before I start tearing out the wires..
