Skoda Favorit 136L - help how to remove Air distributor
Good morning,
I would please need some advice / guide how to remove rear air distributor. Plastic part, which is inside of the car.
It is mounted on the screw and I am not able to remove it. Where is the head of the screw ? Is visible somewhere on chassis ?
Or is this plastic part only clicked on that screw ? But I see screw-threads on that screw. I am able to lift it that plastic part up a bit up a little bit from the gear shift side and am able to move it left and right a bit, but I am afraid not to break it.
I am enclosing pictures.
I will be changing floor isolation, Therefor I need to remove this part.
Haynes does not say anything but i have found something useful in the manual.
