Hello!
So far I have replaced the front axle swingarms, the spacers, the stabilizer cable, the stabilizer So far I have replaced the front axle swingarms, spacers, stabilizer silencer, stabilizer rods, tower bearings, tower tires, shocks, dust shields, shock absorbers, and rims. The outer half-shaft joints have also been replaced. The rear axle shock absorbers and dust cover, rim were also replaced. New rubber bushings on all three engines. Despite these, if there's a bump or road roughness, the car makes a loud clunking noise and shakes all over. Above 60 km/h, the whole car shakes, and periodic knocking/clacking sounds can be heard and felt on the car. The rims were centered in December. Also, in colder weather something makes a quieter clicking sound and I can hear it when I put my ear to the gearshift. But if I pop the clutch, the sound still remains, but you can only hear this soft knocking inside. But the main problem is the loud knocking mentioned earlier. I'm afraid trouble will happen at some point, although the mechanics (4) can't find anything wrong and told me to turn up the radio.
So where do I look, what could be the problem. Thanks for your help and advice.
P.S., the right outside slider has about 1-2mm of dead travel, and when the car is raised there are rattling noises coming from the differential, but I was told that was normal.
