hopefully a soon to be Superb iv owner
Hi All.
Im looking at getting a Superb iv, Think ive settled on spec etc 2021/2 SE, L, under 50k
It will be the daily driver but also an occasional tow car, Caravan 1400kg so within the limits.
I have seen lots of conflicting info online around cars not specked for towing at manufacture, additional cooling but with very few having a factory fitted towbar its a bit of a minefield, so... my questions to you all.
I'm aware tha the weight plate must contain both the Maximum vehicle weight and gross train weight totalling up to 1600kg bit Is there anyting else i need to look for? I remember reading that towbar prep addis additional cooling somewhere, Am i safe to assume if it was plated to tow then this would be included?
Finally, Ideally i would get a factory fit towbar but if i were to go with a 3rd party one with dedicated electrics / vehicle recode am i missing anything by going down this slightly cheaper route - other than having to kneel down and po the tow hook in when i want to use it.
Thanks in advance.
Hello, welcome to the forum.
I suspect you will find that the towing weight being included on the plate does not actually indicate factory towbar preparation has been fitted.
Thanks @Warrior193 I did supect that ould be the case.
Happy to look at an aftermarket one just want to make sure there are no hidden gotchas down the road to think about.
