CAI removed
After only having it on for 48 hours i have teken it off.
I like the extra "throatiness" of the engine but to be honest the loudness of the dump valve is too c.h.a.v. for me and i found it embarrasing.
If that is your thing then fair enough but i think i will be going for a replacement panel filter instead.
So if anyone wants a barely used CAI let me know :rolleyes:
what type is it i might take it
The type off e-bay, good kit.
to be honest the 1.8t engine is quite good on torque but on sound itts crap.
The 1.8T can produce a glorious sound, it just needs a little help.
It is the one off Ebay.
see my previous post here
http://www.briskoda.net/forums/octavia/cai-fitted/56739/
I will either put it back on Ebay or in the Items for sale section on here.
If you want a load of dump valve sound then it is great but it was just too much for my tastes. It certainly made the car a bit more responsive too, and i think the turbo seemed to spin up faster.
Hi, ROb. I see you've done the same thing I did with mine :rofl: The amplified Darth Vader noise is very ch*v with the EBay kit. However, the Carbonio is a bit quieter (well seemed to be when i had a passenger ride in piv34uk's Octavia)
Lots of money to just try out though so it may be worth listening to one to see what you think.
:eek:i must be clearly in the minority because i love the noise of a well set up dump valve,OMG i must be turning ch*v:rofl:
Hadaway! The DV soundtrack is the best bit! I often see the boy racer crowd looking round to see what monstosity is making such a noise, then looking totally confused as me Skud sails past. Class.
Maybe someone who can record the sound?
Solves the problem of not knowing what is does.
(I think a lot are in the dark about the noise, I am!)
A big thanks for that poster in that case!
Ever hear the loud hiss a truck makes as the driver applies the air brakes? Its like a muffled Darth Vader version of that every time you change gear :rolleyes:
Carbonio........... The classy persons choice for induction noise :rofl:
:D Phil;)
(I think a lot are in the dark about the noise' date=' I am!)
A big thanks for that poster in that case![/quote']
I did post a video of mine once with the ABD LAN and CAI fitted.
Should still be hosted, just need to find the post!!
:D Phil;)
I am classy as well then:)
