2012 1.2 77TSI misfire and ESC light
Hi, I know this has been asked so many times before and I promise I have read through a lot of previous posts but can’t fix the issue.
Engine lost power and is running rough as guts with ESC and engine light on. It starts up ok but after 5-20 seconds will start having the misfires with ESC light coming on. The engine light is always on now. Got garage to read out and came back with misfire on cylinder 3.
I have replaced all plugs (NGK iridium) and leads but still persisted. Now I have also changed the coil pack with a new NGK U2003 and hoped that would work but no change whatsoever.
What else can it be? My battery is not great I believe but car starts fine so not sure if it can be related?!
If it’s nothing electrical I can only assume that the engine itself is causing it but an engine failure at 56,000 miles would be ridiculous right?
Hopefully some can point me in the right direction! Thanks in advance.
Hello, welcome to the forum.
Did you inspect the old spark plugs - particularly number 3, how did they look?
Suggest a compression test as the next step.
Edited by Warrior193
extra question
Don't forget the injectors.
I wouldn't be suspecting the battery.
When you say 'Garage readout' what exactly did they use?
VCDS, or a professional (expensive) scan tool, would have given far more than just 'misfire'!
