Oil Sensor - please visit workshop warning light.
I’ve searched the forums and cannot find an exact answer to my question.
I’m getting the OIL SENSOR! Please visit workshop warning message every 5 minutes or so. It pings and then goes off after about 3 seconds.
Oil level is perfect and temperature is holding at about 95/96 so would anyone know what might be causing this?
I’m thinking either faulty sensor, dirty sensor or a wiring issue?
It’s a 1.5 TSI with 116k miles.  The car is a taxi so I have to work whilst worrying about this.
I'd suggest having the oil level sensor replaced as a first choice. Is the warning you get the yellow/amber indicator?
Yes it’s amber thanks. Should be a sensor fault.
I’m about to go under to check the wiring. If nothing looks amiss I’ll order a new sensor from TPS. Unfortunately I think you need to drop the oil to remove it. It’s close to oil change time though I suppose.
You could always try the vacuum cleaner method 🙂
What’s that then???😂
Attach vacuum cleaner to oil filler. Remove sensor and fit new one 😁
Have you used that method successfully?
Seems to be behaving itself now. Hasn't come on for a couple of days now. The car was sitting for five days so might have been an electrical gremlin.
